OptoNews: New ATEX approval for Opto 22 products
Posted by Jean Femia on Jun 8, 2016 4:52:14 PM
ATEX logoATEX is the name commonly given to the two European Directives for controlling explosive atmospheres in workplaces.
Several Opto 22 products are now approved for both standards and offer you options for applications in potentially explosive areas.
The two standards are:
  • EN60079-0, issue date 2012 +A11:2013
    "Electrical apparatus for explosive gas atmospheres. Part 0: General Requirements"
  • EN60079-15, issue date 2013
    "Explosive atmospheres Part 15: Equipment protection by type of protection 'n' "
The following Opto 22 products meet the ATEX standards:
SNAP I/O modules
SNAP-AIMA-4 — Analog current input module, 4 points, -20 mA to +20 mA
SNAP-AIV-4 — Analog voltage input module, 4 points, -10 VDC to +10 VDC
SNAP-AOA-23-iSRC-FM — Analog current loop output module, 2 isolated points, 4-20 mA, with loop sourcing, also Factory Mutual approved
SNAP-AOA-28 — Analog current loop output module, 2 points, 0-20 mA
SNAP-IDC5DFM — Digital input module, 4 points, 2.5-28 VDC, also Factory Mutual approved
SNAP-IDC5FAST — Digital input module, 4 points, 2.5-16 VDC
SNAP-IDC5Q — Digital input module, 4 points, quadrature position
SNAP-ODC5-IFM — Digital output module, 4 isolated points, 5-60 VDC, also Factory Mutual approved
SNAP-SCM-485-422 — Serial communication module, RS-485/422 2-wire or 4-wire, 2 channels
SNAP PAC R-Series controllers
SNAP-PAC-R1-FM — Rack-mounted programmable automation controller (PAC) for analog, digital, and serial I/O, with high-speed digital functions, also Factory Mutual approved
SNAP-PAC-R2-FM — Rack-mounted PAC for analog, digital, and serial I/O, also Factory Mutual approved
SNAP PAC racks
SNAP-PAC-RCK4-FM — I/O rack for rack-mounted PAC and 4 I/O modules, also Factory Mutual approved
SNAP-PAC-RCK12-FM — I/O rack for rack-mounted PAC and 12 I/O modules, also Factory Mutual approved
SNAP power supplies
SNAP-PS5 — Power supply for mounting rack with PAC and I/O modules, 110 VAC to 5 VDC
SNAP-PS5-24DC — Power supply for mounting rack with PAC and I/O, 24 VDC to 5 VDC
SNAP accessories
SNAP-STRAP — Jumper strap for digital I/O modules with 8-wire connector
See the Declaration of Conformity for ATEX products.
See the ATEX Declaration of Conformity
Topics: Process control, Food & beverage, Discrete control, Machine builder, optonews, PACs, OEM, Integrators, I/O, Oil & gas, OptoNews 2016-06-08
Written by Jean Femia
