OptoNews: New compact breakout board saves cabinet space
Posted by Jean Femia on Jan 20, 2016 4:12:04 PM
SNAP-UDC-HDB breakout board for SNAP 32-point digital I/O modulesIf you use high-density 32-point SNAP digital I/O modules, you'll be interested in our latest breakout board: the SNAP-UDC-HDB.
The small footprint of this new board makes it ideal for use in cramped areas. Just 3.32 x 3.95 x 2.27 inches high (8.43 x 10.03 x 5.77 cm), the SNAP-UDC-UDB fits in tight places but still gives you room to wire all 32 points to field devices.
The board uses spring-clamp connectors for faster wiring. To save space, it does not provide fuses. 32 LED indicators are included to show point status for each point.
Plug in a SNAP-HD-BF6 cable to connect the SNAP 32-point module to the board.
The SNAP-UDC-HDB works with any of the following 32-point modules. You'll need one breakout board per module:
Input modules:
Output modules:
See SNAP-UDC-HDB breakout board
Topics: Discrete control, Machine builder, optonews, New products, Integrators, I/O, OptoNews 2016-01-20
Written by Jean Femia
