title: "Available now: 2 new DC output modules for high-current and high-voltage loads"
description: "Get details and specifications for two newly released groov I/O modules: GRV-ODCIHC-12 and GRV-ODCIHV-12."
image: https://blog.opto22.com/hubfs/GRV-ODCIHC-12_p_1600.png
# Available now: 2 new DC output modules for high-current and high-voltage loads
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Jul 29, 2026, 7:38:52 AM
### Get details and specifications for two newly released *groov* I/O modules: GRV-ODCIHC-12 and GRV-ODCIHV-12.
Explore more options for your *groov* EPIC system with the release of two *groov* DC output modules.
Do your applications require driving high-current or high-voltage DC loads? Take a closer look at how these new I/O modules can help.
##### [GRV-ODCIHC-12 - Drive larger DC loads without interposing relays](https://www.opto22.com/products/product-container/grv-odcihc-12)
[![GRV-ODCIHC-12\_p\_1600](https://blog.opto22.com/hs-fs/hubfs/GRV-ODCIHC-12_p_1600.png?width=250&height=250&name=GRV-ODCIHC-12_p_1600.png)](https://www.opto22.com/products/product-container/grv-odcihc-12)The **GRV-ODCIHC-12** discrete DC output module provides 12 isolated 0–60 VDC output channels, each switching a separate DC load. This module is ideal for applications that require driving high-current loads of up to 6 A per channel, eliminating the need for interposing relays in DC circuits.
Typical applications include:
- Large solenoid valves
- Contactor coils
- Brake coils
- Industrial lighting
- Large DC relays
- DC motors
- Magnetic locks
- Industrial buzzers and horns
Industries that can benefit:
- Factory automation
- Packaging machinery
- Material handling
- Food & beverage
- Water/wastewater
- Oil & gas
- Automotive manufacturing
- Semiconductor equipment
Like all *groov* digital modules, the GRV-ODCIHC-12's hinged cover includes an LED array that indicates status, along with a touch-sensitive pad that triggers the *groov* EPIC processor to display module information, including specifications and a wiring diagram.
It provides a full set of features, including:
- On/off state
- On/off totalization
- Output pulsing/TPO
See the [GRV-ODCIHC-12 data sheet](https://documents.opto22.com/2238_groov_DC_Output_Modules_Data_Sheet.pdf) for complete product specifications.
[![GRV-ODCIHC-12](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/c4addc3e-0c7e-41ce-aed4-86844f00938d.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/c4addc3e-0c7e-41ce-aed4-86844f00938d)
##### [GRV-ODCIHV-12 - Connect to DC control systems up to 150 VDC](https://www.opto22.com/products/product-container/grv-odcihv-12)
[![GRV-ODCIHV-12\_p\_1600](https://blog.opto22.com/hs-fs/hubfs/GRV-ODCIHV-12_p_1600.png?width=250&height=250&name=GRV-ODCIHV-12_p_1600.png)](https://www.opto22.com/products/product-container/grv-odcihv-12)The **GRV-ODCIHV-12** discrete DC output module offers 12 channels of 0–150 VDC output, each channel switching a separate DC load. This module is perfect for applications that need to drive higher-voltage loads, which are common when reliability over long distances is important, or legacy standards persist.
- Electrical substations
- Power generation
- Transmission & distribution
- Rail & transit
- Mining
- Marine & offshore
- Petrochemical plants
- Legacy industrial plants
Again, like all *groov* digital modules, its hinged cover includes an LED array that indicates status, along with a touch-sensitive pad that triggers the *groov* EPIC processor to display module information, including specifications and a wiring diagram.
This module includes the full feature set:
- On/off state
See the [GRV-ODCIHV-12 data sheet](https://documents.opto22.com/2238_groov_DC_Output_Modules_Data_Sheet.pdf) for complete product specifications.
[![GRV-ODCIHV-12](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/4ab5d311-abc2-4dd0-84ac-b096dabaee84.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/4ab5d311-abc2-4dd0-84ac-b096dabaee84)
Both modules are UL/cUL-listed for Class 1, Div. 2 hazardous locations and carry CE and UKCA marks. Each *groov* I/O module is factory-tested twice before shipment, and most are guaranteed for life.
*More questions about these new products?*
Start a live [OptoChat](https://www.opto22.com/) with an Opto engineer, use the [Contact Us](https://www.opto22.com/support/contact-us) form on the website, or drop a question in the comments below. We're ready to help!
 Topics: [I/O](https://blog.opto22.com/optoblog/topic/io), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
