title: "Crusher controls that travel: a smarter approach to mobile automation"
description: New case study shows you how Hunt Electric standardized its mobile crusher controls and walked away from the PLC licensing trap.
image: https://blog.opto22.com/hubfs/HuntVan_1200.png
# Crusher controls that travel: a smarter approach to mobile automation
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Nov 18, 2026, 8:37:25 AM
### New case study shows you how Hunt Electric standardized its mobile crusher controls and walked away from the PLC licensing trap.
What if you could build a control system for a job before knowing exactly what that job would require—and adapt it later without starting over?
 That's the challenge OptoPartner Hunt Electric faced when designing mobile control systems for aggregate crushing operations.
Read the latest Opto 22 case study that explains how they created flexible, mobile control vans to adapt to their changing site requirements.
![HuntVan\_1200](https://blog.opto22.com/hs-fs/hubfs/HuntVan_1200.png?width=700&height=394&name=HuntVan_1200.png)
[![READ CASE STUDY](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/548d09a6-17d0-47b2-bc4b-a84a7ffa8a77.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/548d09a6-17d0-47b2-bc4b-a84a7ffa8a77)
You'll learn how [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) controllers helped [Hunt Electric](https://www.opto22.com/community/opto-partners/partner?id=1201):
- **Eliminate costly software licensing headaches** with a controller that doesn't require recurring license fees.
- **Simplify mobile control system design** with flexible, modular I/O and reusable programming.
- **Reduce installation and troubleshooting time** with built-in touchscreen configuration and remote access.
- **Avoid unnecessary service calls** by diagnosing and resolving problems remotely.
- **Build for future expansion** with a flexible architecture that can accommodate new equipment and changing operational needs.
![Opto-Quote-hunt\_111326](https://blog.opto22.com/hs-fs/hubfs/Opto-Quote-hunt_111326.png?width=550&height=550&name=Opto-Quote-hunt_111326.png)
[Read the complete case study](https://www.opto22.com/products/case-study/crusher-controls-that-travel) on our website or [download your own PDF](https://www.opto22.com/support/resources-tools/documents/2463-case-study-crusher-controls-that-travel) copy.
Visit our [Case Study library](https://www.opto22.com/products/case-study) for more application success stories featuring [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) and [*groov* RIO](https://www.opto22.com/products/groov-rio).
Do you have an application you'd like to share? Learn more about our [Case Study Program](https://info.opto22.com/opto-22-case-study-program-interest-form-v2) and how it can help set you apart as an industry expert.
 Topics: [Case studies](https://blog.opto22.com/optoblog/topic/case-studies), [Remote monitoring](https://blog.opto22.com/optoblog/topic/remote-monitoring), [CODESYS](https://blog.opto22.com/optoblog/topic/codesys), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [mining](https://blog.opto22.com/optoblog/topic/mining)
