title: Help is here for OEM machine designers
description: Check out this new website resource to learn how groov products help you build better machines.
image: https://blog.opto22.com/hubfs/Mercer-Heat-Treatment-FurnaceExterior600.png
# Help is here for OEM machine designers
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Jul 9, 2025, 7:12:22 AM
### Check out this new website resource to learn how *groov* products help you build better machines.
As an Original Equipment Manufacturer (OEM), what sets you apart in your industry? How can you provide more value to your customers?
Opto 22 *groov* products are designed with OEM machine builders in mind. That's why you'll want to check out this new website resource dedicated to OEMs. It shows how you can:
- Stand out with your customers
- Reduce initial costs
- Reduce ongoing costs
Learn how to build better machines and get the technical support you're counting on.
[![Mercer-Heat-Treatment-FurnaceExterior600](https://blog.opto22.com/hs-fs/hubfs/Mercer-Heat-Treatment-FurnaceExterior600.png?width=600&height=450&name=Mercer-Heat-Treatment-FurnaceExterior600.png)](https://www.opto22.com/support/talk-to-an-engineer)
[![OEM WEB RESOURCES](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/385b15f3-7df7-44d0-b7b6-7f1e90a2e395.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/385b15f3-7df7-44d0-b7b6-7f1e90a2e395)
On the OEM Machine Design page, you'll find case studies that showcase how manufacturers put themselves ahead of their competition.
You'll see how to:
- Design, deploy, and support intelligent machines with [built-in control](https://www.opto22.com/products/product-families/groov/real-time-control), data collection, and secure remote VPN access.
- Build once, deploy everywhere—with a platform that carries your identity and your value through every customer touchpoint.
- Turn customer performance data into insights they can use for better decisions.
- Build machines using your preferred tools—[IEC61131-3](https://www.opto22.com/products/groov-epic-system/groov-epic-software/codesys-(iec-61131-3)), Python, Docker, [Node-RED](https://www.opto22.com/products/groov-epic-system/groov-epic-software/node-red)—and deploy across models and generations.
##### [![www.designworldonline.comwp-contentuploadsgroovRIO-groveEPIC](https://blog.opto22.com/hs-fs/hubfs/social-suggested-images/www.designworldonline.comwp-contentuploadsgroovRIO-groveEPIC.jpg?width=300&height=316&name=www.designworldonline.comwp-contentuploadsgroovRIO-groveEPIC.jpg)](https://www.opto22.com/products/oem-machine-designers)
##### And Opto 22 is here to help...
- You’re not just buying parts—you’re gaining a team.
- [Work directly with experienced engineers](https://www.opto22.com/support/talk-to-an-engineer). No rep firms. No red tape. Just fast help from people who know your application.
- Get [free training](https://www.opto22.com/support/training-options), free development tools, and [**FREE** **ongoing support**](https://www.opto22.com/support).
Get started by reviewing the [Machine Designer resources](https://www.opto22.com/products/oem-machine-designers) and learning how [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) and [*groov* RIO](https://www.opto22.com/products/groov-rio) can help achieve your manufacturing goals.
*More questions? * [Talk to an Opto Engineer](https://www.opto22.com/support/talk-to-an-engineer).
 Topics: [Machine builder](https://blog.opto22.com/optoblog/topic/machine-builder), [OEM](https://blog.opto22.com/optoblog/topic/oem), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio)
