Opto 22's new Data Center Solution brochure outlines how to provide industrial edge control for your mission-critical infrastructure.
As data centers grow to support AI, cloud computing, and increasingly demanding workloads, reliable monitoring, control, and data access are more important than ever.
How can you build automation solutions that keep critical systems running while adapting to changing needs?
Opto 22’s new Data Center Solution brochure explores how groov EPIC can help address these challenges.
Your data center runs like a factory—you can control it like one
When every second of uptime matters, data center operators need reliable ways to monitor critical equipment, manage cooling systems, and turn operational data into meaningful insights. But how do you connect diverse systems and maintain control as data center demands continue to grow?
Opto 22’s new Data Center Solution brochure explores how groov EPIC can help address these challenges. Discover how industrial-grade control, flexible connectivity, and edge data processing can support data center applications, including equipment monitoring, cooling systems, and other critical infrastructure.
Whether you design data center systems, integrate automation, or manage facility operations, this brochure is a valuable resource for understanding how Opto 22 technology can help you connect equipment, access data, and build solutions designed to scale.
The brochure also references a recent data center case study. Learn why Nautilus Data Technologies turned to liquid cooling for data centers and stable control at scale.
Ready to explore the possibilities? Download the new Opto 22 Data Center Solution brochure and discover how groov EPIC can support your next data center project.
