title: Missed Node-RED Con 2026? Catch up with free recordings!
description: Watch the complete playlist of session recordings from Node-RED Con 2026 and see the latest industrial projects from around the world using Node-RED programming.
image: https://blog.opto22.com/hubfs/NodeREDCon2026RecordingsKeynote.png
# Missed Node-RED Con 2026? Catch up with free recordings!
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Nov 11, 2026, 7:02:29 AM
### Watch the complete playlist of session recordings from Node-RED Con 2026 and see the latest industrial projects from around the world using Node-RED programming.
Couldn't attend Node-RED Con 2026, or want to revisit some of the presentations? You're in luck! The event recordings are now available for free in a YouTube playlist.
Whether you're an experienced Node-RED user or just getting started, these sessions offer an opportunity to explore new ideas, learn from the community, and discover practical applications. This year's theme, Edge of Intelligence, focuses on building with Node-RED in edge deployments, industrial automation, and AI integration.
Take advantage of this free resource and watch the sessions that interest you the most.
[![NodeREDCon2026RecordingsKeynote](https://blog.opto22.com/hs-fs/hubfs/NodeREDCon2026RecordingsKeynote.png?width=673&height=373&name=NodeREDCon2026RecordingsKeynote.png)](https://www.youtube.com/playlist?list=PLfYexYfK6OFo)
[![WATCH NODE-RED CON 2026](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/e4bb53b3-2d23-455b-b0f4-9be52baeef07.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/e4bb53b3-2d23-455b-b0f4-9be52baeef07)
You can catch up at your own pace, revisit presentations, and pick up insights you can put to work in your own projects. Remember, Node-RED is included in Opto 22's [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) and [*groov* RIO](https://www.opto22.com/products/groov-rio) edge devices.
In Node-RED, you connect prebuilt nodes (provided by device manufacturers or software developers) together to make a flow. The flow provides the logic to accomplish your goal. You can also add function nodes containing JavaScript.
Because Node-RED is a general-purpose programming environment, you have the freedom to create flows you like using any nodes you choose. Opto 22 *groov* I/O nodes, PAC Control nodes (for *groov* EPIC processors and SNAP PAC controllers), *groov* View Data Store nodes, and a wide variety of other nodes are easy to install.
Have more questions after watching the conference? Use the Node-RED resource list below, or [talk to an Opto 22 engineer](https://www.opto22.com/support/talk-to-an-engineer) about your application.
#### Additional Resources for Node-RED
- [Node-Red Workshops](https://www.opto22.com/support/resources-tools/videos/playlist-node-red-workshops) (videos)
- [OptoU - Node-RED online training](https://training.opto22.com/path/node-red)
- [developer.opto22.com](http://developer.opto22.com/nodered/general/) (includes code samples)
- Get and give help on using Node-RED in the [Node-RED OptoForum](https://forums.opto22.com/c/node-red)
- [Developing with *groov* EPIC](http://developer.opto22.com/epicdev/)(Opto 22 Developer site)
 Topics: [Webinars](https://blog.opto22.com/optoblog/topic/webinars), [Events & conferences](https://blog.opto22.com/optoblog/topic/events-conferences), [Node-RED](https://blog.opto22.com/optoblog/topic/node-red), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio)
- [groov EPIC (517)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (309)](https://blog.opto22.com/optoblog/topic/groov-rio)
- [Webinars (71)](https://blog.opto22.com/optoblog/topic/webinars)
