Unleashed in Sacramento: An ICC 2026 Recap
Posted by Dan White on Oct 7, 2026, 9:32:52 AM
Experience the Ignition Community Conference through an Opto 22 perspective and learn why it's growing in relevance and attendance every year.
If you were at #ICCUnleashed in Sacramento, you felt it. If you weren't, here's the short version: the Ignition community keeps growing, and almost everyone I talked to wants the same thing, real data from their machines, new and old, flowing into Ignition.
Inductive Automation brought nearly 2,000 people to the SAFE Credit Union Convention Center September 22 to 24. That's nearly 2,000 different versions of ICC. I saw mine from behind the Opto 22 booth and from the stage as a speaker.
Here's a recap of the experience and why it's important to be a part of this growing Ignition community.
ICC2026Keynote1000
Ignition 2027 and Catalyst
I was eager to attend the opening keynote. The headliner: Ignition 2027 with Catalyst, which Inductive describes as "a secure framework for working with AI inside Ignition."
Catalyst will be huge in speeding up project development in Ignition. You connect the AI model you choose, from cloud models like ChatGPT, Claude, and Gemini to a local LLM running on Ollama for air-gapped sites. Catalyst Core builds a Designer Assistant into Ignition that helps you write scripts, expressions, and SQL queries, configure UDTs, and build Perspective views. Amazing to see how far we’ve come since last year.
ICC2026BlogLogo
Also on the list: an Enterprise Historian Module for Tiger Data’s TimescaleDB, better design tools, automated deployments, and multi-site management.
Get the full rundown in Inductive Automation's announcement.
Team Opto at ICC
Opto 22 showed up as a Diamond sponsor with a full crew. Here's where you could find us:
Closest to the pin
ICC started early for us, on the golf course. Opto 22 hosted the closest-to-the-pin challenge at the ICC golf tournament at Bing Maloney Golf Course. Derrick Chambers of SkyIO stuck it closest, just 21 inches from the pin on a tricky par 3.
ICC2026BlogGolf
His prize? Two free seats at Opto 22's Premium Factory Training. Congrats, Derrick!
Want a seat of your own, no golf required? Check out the newly released Premium Factory Training schedule and pick a date that works for you.
At Booth 3: eight partners in one factory
Booth 3 stayed busy all three days. Old friends, new faces, and a lot of good conversations.
The big draw was our ACME Dynamite demo: one fictional factory built by eight partners, each handling the layer it does best. Thanks to Cirrus Link, Inductive Automation, Sepasoft, 4IR Solutions, Joltek, Avadine, and Kanoa for building it with us.
ICC2026BlogBooth
The demo is still live at op22.co/acme if you want to poke around.
On the Gateway Theater stage: Benson and Garrick
Wednesday morning, Benson Hougland and Garrick Reichert took the Gateway Theater stage for "Close the Gaps: Connect any asset to Ignition with Opto 22's groov EPIC & RIO." Using our ACME demo, they showed live how groov EPIC and groov RIO bring legacy PLCs, standalone skids, and unconnected machines into Ignition. You can run Ignition Edge on your groov device directly, or use our built-in data service to publish data over MQTT Sparkplug or expose it with OPC UA.
ICC2026Showcase1
Then Vlad Romanov of Joltek came on stage with a brownfield problem. Joltek's palletizer cell runs on an Allen-Bradley CompactLogix 5380 with no security of its own. How do you update its program remotely without exposing it? A groov RIO in front of the PLC runs an OpenVPN client, and Avadine's Opto 22 Integration Module controls the VPN and port redirects from Ignition. Open a conduit for Studio 5000 when you need it. Close it when you're done.
Thanks again to everyone who built the ACME factory with us: Cirrus Link (MQTT), Inductive Automation (SCADA), Sepasoft (batch and MES), 4IR Solutions (cloud hosting), Joltek (palletizer), Avadine (remote access), and Kanoa (maintenance). It takes a team to build a factory, even a fictional one.
In the workshop: Garrick
On Tuesday, Garrick Reichert ran a hands-on workshop, "Collect, Model, and Democratize OT Data With Ignition Edge." Attendees worked through the full edge data path. They collected data from PLCs and devices with Ignition's simulation driver, modeled it into UDTs, and published it securely over MQTT Sparkplug to Ignition and Ignition Cloud Edition. I didn't make it in, but the room was full, and everyone left with the same pattern they can use on their own equipment.
Missed it? Work through the same steps at your own pace with our Ignition Edge workshop videos.
ICC2026Workshop1000
On the Grand Theater stage: Chris Raymond and me
Tuesday afternoon, I joined Chris Raymond of Surety Automation in the Grand Theater for "Unleashing Edge Intelligence in Remote Mining Operations." A mine is the toughest control environment I can think of. If an architecture works a mile underground, it'll work in your plant.
SuretyAutoSession1
When a sump pump fails underground, water can rise 12 to 16 feet a day. Chris's customer, a Nevada gold mine, asked for a PLC per level. Surety built one small panel per station instead: a groov RIO running CODESYS, smart devices, and Ignition Edge, all on one network drop. Store-and-forward saves every data point when blasting cuts the network.
The cost savings over a full PLC panel are why the project grew from five stations to twelve. Chris now uses the same architecture on projects in other industries, including a cement plant and a 48-site gas pipeline.
Read the full story in From Smart Sumps to Smarter Mines.
At the Build-a-Thon: our data center panels
The Ignition Build-a-Thon in the Grand Theater is always a highlight. Both finalists built on our groov EPIC data centers, small-scale models of real data center infrastructure with both air-cooled and liquid-cooled systems.
Then they took them in very different directions. BW Design Group, the 2023 champs, launched theirs into orbit with a data center in space. First-time finalist Prime Controls fired up a BBQ project. It came down to the wire, and BW Design Group barely edged out Prime Controls for the title. Congrats to both teams.
And a big thanks to Terry Orchard and Michael Miller, our Build-a-Thon construction team. They designed and built these rigs from the ground up and did a great job on the big stage!
ICC2026BlogBaT
Thinking of using groov for your data center? See how in the groov EPIC for Data Centers brochure.
In the Discover Gallery: East 15 Technologies
You could also find Opto 22 gear in the Discover Gallery. East 15 Technologies won a Firebrand Award for its Digital Ship System at Seaspan Ferries. It connects six vessels and four terminals into one Ignition platform, with Ignition Edge running on groov EPIC controllers on every ship. Vessel telemetry and terminal data come together so Seaspan can track fuel use, schedule adherence, and vessel health on every voyage, even during unmanned periods. That's 100,000+ tags, built by a team of one.
Congrats, Joseph Donohue! See the full project.
ICC2026BlogEast15winner
After hours
And of course, a lot of the community happens after the sessions end. Tuesday was karaoke night. On Wednesday, we ended up at the Dive Bar (yes, the one with the mermaid). Thursday's speaker appreciation dinner closed out an amazing week.
Thanks to Inductive Automation for another well-run ICC, and to everyone who stopped by, sang along, or shared a table.
See you at ICC 2027
ICC 2027 is already on the calendar for October 5 to 7, 2027. So save the date.
ICC2026BlogRecap
In the meantime, if you're working out how to get data from new or existing equipment into Ignition, talk to an Opto 22 engineer. We'll help you figure out where to start.
Topics: Events & conferences, groov EPIC, Ignition, Ignition Community Conference, groov RIO
Written by Dan White
