OptoNews: IIoT tool Node-RED included in new groov Admin release
Posted by Jean Femia on Oct 26, 2016 3:11:05 PM
groov Box with Node-RED for IIoT projectsJust released! A major new tool for your Industrial Internet of Things (IIoT) project: the groov Box with Node-RED built in.
What is Node-RED?
It's an open-source, cross-platform tool for wiring together hardware devices, databases, cloud services, and APIs (application program interfaces) with simple logic flows.
It's a fast-track way to start achieving your IIoT goals with little or no programming. Or if you're not quite ready for the IIoT, Node-RED makes it simple to share data with databases or other software applications.
Node-RED offers hundreds of free, pre-built nodes from hardware manufacturers and software developers. Just a few: MySQL databases, online weather services, and Opto 22 SNAP PAC controllers.
Why is it in the groov Box?
Node-RED in the groov Box means you now have an industrially hardened platform to run your Node-RED flows on, plus you'll save the time and effort normally required to install and configure Node-RED on a computer or embedded device. All you have to do is securely log in and start building a flow. Steps for getting started are in Chapter 4 of the groov Box User's Guide for GROOV-AR1.
Add that convenience to the super-easy way groov lets you create and use mobile operator interfaces to virtually any system or equipment, and you've gone a long way toward 21st Century monitoring and control.
Of course the two Opto 22 SNAP PAC Node-RED nodes are included. Thanks to the new RESTful API in SNAP PAC programmable automation controllers, these nodes provide access to I/O point and variable data in SNAP PACs.
We've also included our web-based Node-RED Admin utility, which provides secure, authenticated access to your Node-RED flows, backup and restoration, a resources dashboard, and a way to administer security certificates for your SNAP PAC controllers.
How do I get it?
If you already have a GROOV-AR1 groov Box appliance with a current license, just log into manage.groov.com and download and install the new groov Admin R1.570.45. Node-RED is included in the new release.
Note that Node-RED is available only for the GROOV-AR1, not for the older GROOV-AT1 box and not for groov Server for Windows. (If you have groov Server, you can get Node-RED from nodered.org and run it on your Windows PC.)
If you don't have a groov Box yet, take a look at its specs and capabilities
See the groov Box with Node-RED
Topics: groov, Internet of Things, Updates, IoT, optonews, PACs, mobile, IIoT, Industrial Internet of Things, OptoNews 2016-10-26, Node-RED
Written by Jean Femia
