OptoNews: Send temperature data to AT&T M2X in the cloud
Posted by Jean Femia on Mar 29, 2017 3:54:29 PM
AT&T M2X logoHave you tried AT&T's Internet of Things (IoT) platform, M2X?
If you're looking at IoT platforms, you'll want to see this new technical note. It shows you how to get real-world data, in this example a temperature in degrees F, to an AT&T M2X device in the cloud.
Technical Note: Connect Real-world Data to an AT&T M2X Device
You'll need an Opto 22 SNAP PAC controller (R‑series or S‑series), and you'll be using the PAC's RESTful API and HTTP/S server.
You'll also need an account on m2x.att.com (you can start for free) and a configured device there.
The example in the tech note uses a SNAP-PAC-R1 that’s part of a SNAP-PACLC Learning Center. The Learning Center is handy for experimenting and proofs-of-concept, because it includes SNAP I/O modules and a load panel, as well as the PAC. You can program the PAC and see everything work, right there.
Get the tech note and try AT&T M2x now.
Get the technical note
Topics: Internet of Things, IoT, optonews, PACs, IIoT, Industrial Internet of Things, Node-RED, Data acquisition, OptoNews 2017-03-29
Written by Jean Femia
