Accelerate your application
Posted by Dan White on Jul 16, 2025, 8:05:25โ€ฏAM
Take advantage of free tools to jumpstart your industrial automation projects.
Whether you're an engineer, technician, or developer, starting a new project can be daunting. But what if you could hit the ground running with resources that streamline your workflow?
Let's explore how you can accelerate your application using a suite of free tools designed to simplify and expedite your development process.
๐Ÿš€ 1. Ignition Exchange: Pre-built resources for rapid development
The Ignition Exchange has free, community-driven resources. You'll find HMIs, dashboards, scripts, and templates that you can drop right into your projects. Whether you're building a new SCADA system or improving an existing one, the Exchange can save you serious development time.
AccelerateIgnitionExchange
๐Ÿงฐ 2. CODESYS Forge: Open-source portal for PLC programming
If you're using CODESYS in your automation project, check out the CODESYS Forge for free examples and open-source projects. You'll find code for basic control logic to complex motion control, with examples and code snippets to speed up your work.
AccelerateblogCODESYS
๐ŸŽจ 3. Opto 22's free image libraries: enhance your visualizations
Opto 22 offers you a free SVG image library and GIF animations to help you create clear HMIs. You can easily add these graphics to groov View and other visualization platforms, improving user experience and system clarity.
AccelerateSVGImageLib
๐Ÿงช 4. PAC Control samples: learn by example
If you're working with Opto 22's PAC Control, check out the sample strategies. These examples show best practices and give you a good starting point for building your own control strategies. They help you avoid common mistakes and speed up development.
AcceleratePACControl
๐Ÿ’ป 5. Opto 22 developer portal: code your way
The Opto 22 Developer Portal gives you pre-built libraries and APIs for Python, Node-RED, JavaScript, and more. You can work in the environment you know best and connect groov hardware directly to your applications.
AccelerateDeveloper
๐Ÿ”„ 6. Node-RED community flows: visual programming made easy
Node-RED's Flow Library is a rich resource of user-contributed flows that can simplify complex tasks. Whether you're looking to implement MQTT communication, integrate with cloud services, or create custom dashboards, these examples can serve as a valuable starting point.
AccelerateNodeRed
๐Ÿ 7. Python automation projects: scripts to streamline tasks
Python's versatility makes it a popular choice for automation. Platforms like GitHub host numerous open-source projects that can help you automate tasks ranging from data analysis to machine learning. Exploring these repositories can provide inspiration and code snippets to enhance your applications.
AcceleratePython
๐Ÿ“ˆ Conclusion: empower your projects with ready-made resources
Using these free tools and resources can cut your development time and improve your industrial automation projects. When you start with tested examples and templates you can customize, you spend more time on new ideas and less time on basic setup.
Topics: PAC Control, Node-RED, CODESYS, groov EPIC, developer, Ignition, groov RIO, python
Written by Dan White
Dan has worked at Opto 22 for more than a decade. His Tufts Engineering background, MBA in International Business, and prior industrial controls experience give him a unique edge in automation. Dan enjoys staying active through biking, basketball, skiing โ€“ and keeping up with his three young kids!
