title: CODESYS Library Package gets new OptoMMP features
description: Version 3.0.0 of the Opto 22 Library Package for the CODESYS Development System has been released.
image: https://blog.opto22.com/hubfs/social-suggested-images/blog.opto22.comhubfscodesys-Jul-18-2022-05-30-16-65-PM.png
# CODESYS Library Package gets new OptoMMP features
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Oct 19, 2022, 12:24:26 PM
### Version 3.0.0 of the Opto 22 Library Package for the CODESYS Development System is now available.
[![blog.opto22.comhubfscodesys-Jul-18-2022-05-30-16-65-PM](https://blog.opto22.com/hs-fs/hubfs/social-suggested-images/blog.opto22.comhubfscodesys-Jul-18-2022-05-30-16-65-PM.png?width=200&height=200&name=blog.opto22.comhubfscodesys-Jul-18-2022-05-30-16-65-PM.png)](https://www.opto22.com/support/resources-tools/downloads/opto-22-library-package-for-codesys-development-sy)For all of you taking advantage of the CODESYS programming environment available for *groov* EPIC, you'll want to hear about this week's [version 3.0.0](https://www.opto22.com/support/resources-tools/downloads/opto-22-library-package-for-codesys-development-sy) release of the Opto 22 CODESYS library package. With CODESYS, you can program *groov* EPIC for industrial control and monitoring using any familiar IEC 61131-3 compliant language.
Version 3.0.0 brings you a new collection of OptoMMP client function blocks you can use to access any area of an Opto 22 device's memory map.
The IEC 61131-3 standard includes several languages, some of which you may already know. [*groov*](https://www.opto22.com/products/groov-epic-system)[EPIC](https://www.opto22.com/products/groov-epic-system) supports all IEC 61131-3 compliant languages, including:
- Function Block Diagram (FBD)
- Structured Text (ST)
- Sequential Function Charts (SFC)
- Ladder Diagram (LD)
The OptoMMP memory map provides a programming interface to an Opto 22 device's I/O and other features. The new function blocks are:
- MmpClient
- MmpClientReadBlock
- MmpClientWriteBlock
- MmpClientReadQuad
- MmpClientWriteUDINT
- MmpClientWriteReal
#### What are Opto's engineers most excited about for this release?
The most significant update is the ability to get quality and status data from I/O modules and their channels. Now you can parameterize all configuration, quality, and status info into your CODESYS control logic.
You could use these function blocks to save I/O configuration data within your CODESYS project, or even configure I/O via your HMI. Using these functions also lets you leverage the OptoMMP Scratch Pad area and integrate many legacy Opto 22 systems into your projects.
[![GET CODESYS 3.0.0](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/1389dab7-04d6-4216-8c8a-689d8e68f3c1.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/1389dab7-04d6-4216-8c8a-689d8e68f3c1)
For the details on this latest 3.0.0 library package, please see the[release notes](https://documents.opto22.com/RM_Library_Package_for_CODESYS.pdf).
If you're just getting started with CODESYS on groov EPIC, the CODESYS Development System is available at no charge from the CODESYS Store at [https://store.codesys.com](https://store.codesys.com/). To enable the CODESYS Runtime for *groov* EPIC, order [GROOV-LIC-CRE](https://www.opto22.com/products/product-container/groov-lic-cre) (also at no charge) and follow steps in the [*groov* EPIC User's Guide](https://www.opto22.com/support/resources-tools/documents/2267-groov-epic-user-s-guide) for licensing.
Interested in learning more about programming with CODESYS? Check out these resources:
- [Opto 22 Library Package for CODESYS Development System](https://www.opto22.com/support/resources-tools/downloads/opto-22-library-package-for-codesys-development-sy)
- [OptoU: CODESYS Library Package Installation and Use](https://training.opto22.com/path/codesys)
- [CODESYS Store](https://store.codesys.com/)
- [Opto 22 Developer Site - CODESYS](https://developer.opto22.com/codesys/)
- [Developing with *groov* EPIC](http://developer.opto22.com/epicdev/)
- [CODESYS blog series](https://blog.opto22.com/optoblog/topic/codesys-blog-series)
And don't forget to [update to 3.0.0](https://www.opto22.com/support/resources-tools/downloads/opto-22-library-package-for-codesys-development-sy)!
 Topics: [Updates](https://blog.opto22.com/optoblog/topic/updates), [CODESYS](https://blog.opto22.com/optoblog/topic/codesys), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov EPIC (517)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (309)](https://blog.opto22.com/optoblog/topic/groov-rio)
- [Webinars (71)](https://blog.opto22.com/optoblog/topic/webinars)
