Create a data table in Node-RED
Posted by Janice Colmer on May 2, 2022, 1:37:37 PM
Next up in the Node-RED developer video series is a tutorial on adding data tables.
Did you know that you can install additional gadgets to the Node-RED dashboard? Terry Orchard returns to the OptoStudio to show off the features of the ui-table node. Learn how to install the table node package and configure different kinds of tables to fit your needs, complete with several examples using live, real-world data.
How to Create a Data Table in Node-RED Dashboard
If there's a particular section or topic in the video you'd like to see again, just click on the bulleted list symbol in the lower right corner of the video for a list of chapters. Simply click on the chapter you'd like to watch again.
To get the most out of this tutorial, it's recommended that you have some familiarity with Node-RED programming, the Node-RED dashboard, and JSON formatting. If not, here are two other videos, you might want to check out first:
And as always, thanks for watching!
Topics: Videos, Node-RED, groov EPIC, groov RIO
Written by Janice Colmer
