title: Get help writing a CODESYS project
description: Learn how to leverage your PLC programming skills on groov EPIC with CODESYS.
image: https://blog.opto22.com/hubfs/social-suggested-images/blog.opto22.comhubfscodesys-Apr-02-2025-04-13-47-5668-PM.png
# Get help writing a CODESYS project
Posted by [Norma Rodriguez](https://blog.opto22.com/optoblog/author/norma-rodriguez) on Apr 16, 2025, 6:05:25 AM
### Learn how to leverage your PLC programming skills on *groov* EPIC with CODESYS.
Are you ready to write a control program for your [*groov* EPIC](https://www.opto22.com/products/groov-epic-system)*,* but unsure where to begin?
Good news: your PLC programming background gives you a head start—especially if you choose to work with **CODESYS**, one of the three control programming options available on *groov* EPIC.
Find out how to use the PC-based CODESYS Development System to create and compile IEC 61131-3 programs that you might already be familiar with.
*groov* EPIC controllers support three control programming methods:
- [**CODESYS**](https://www.opto22.com/products/groov-epic-system/groov-epic-software/codesys-(iec-61131-3))– a fully compliant IEC 61131-3 environment
- [**PAC Control**](https://www.opto22.com/products/groov-epic-system/groov-epic-software/pac-control) – Opto 22’s flowchart-based, easy-to-learn programming language
- [**Secure Shell (SSH)**](https://www.opto22.com/products/groov-epic-system/groov-epic-software/ssh) – for running custom programs in a Linux shell
But if you’re already familiar with ladder logic or structured text, CODESYS is likely the most natural fit.
##### Why Choose CODESYS?
If you've worked with IEC-61131-3 languages, CODESYS will feel familiar right away. Still, you might wonder:
- What libraries do I need?
- How do I configure my controller and I/O?
- Where do I begin writing the logic?
No worries—there’s help to get you started.
##### Get Step-by-Step Help from OptoU
[OptoU](https://training.opto22.com/path/codesys)(Opto 22's free online training) offers a complete set of step-by-step [CODESYS lessons](https://training.opto22.com/path/codesys) designed to get you running quickly. These lessons guide you through:
- Installing the necessary libraries to recognize your *groov* hardware
- Configuring your controller and I/O modules
- Writing and running logic in both Structured Text and Ladder Logic
- Connecting your CODESYS tags to a *groov* View HMI
- Connecting *groov* EPIC as a Modbus Master with CODESYS
[![CodesysLessonsOptoU-1](https://blog.opto22.com/hs-fs/hubfs/CodesysLessonsOptoU-1.png?width=800&height=158&name=CodesysLessonsOptoU-1.png)](https://training.opto22.com/path/codesys)
Follow along with a [*groov* EPIC Learning Center](https://www.opto22.com/products/grv-epic-lc2) or with the [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) and I/O modules you already have.
By the end of the lessons, you’ll have a fully functional control project—and a repeatable process you can use for future systems.
![CodesysSampleNormaOptoU](https://blog.opto22.com/hs-fs/hubfs/CodesysSampleNormaOptoU.png?width=700&height=455&name=CodesysSampleNormaOptoU.png)
##### [![SEE CODESYS LESSONS](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/bcb88ac3-e804-4104-b454-714cfb12d2cf.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/bcb88ac3-e804-4104-b454-714cfb12d2cf)
##### More Reasons to Use CODESYS
CODESYS offers some powerful benefits beyond its familiar programming environment:
- **Open source compatibility** – You can import code that’s compatible with OpenPLC, saving you time when reusing or adapting existing projects.
- **Protocol support** – With CODESYS, your *groov* EPIC can communicate over multiple industrial protocols, including:
    - CODESYS OPC UA (Server/Client)
    - CODESYS Modbus TCP
    - CODESYS BACnet SL
    - CODESYS EtherCAT Master SL
    - CODESYS CANopen Manager SL
    - CODESYS EtherNet/IP Adapter (Slave) SL
    - CODESYS EtherNet/IP Scanner (Master) SL
##### The Bottom Line
If you're looking for a flexible, powerful way to program your *groov* EPIC—and especially if you have PLC experience—CODESYS is the perfect fit. With broad protocol support, open source compatibility, and easy-to-follow training from OptoU, you’ll be well-equipped to easily build robust control systems.
 Topics: [Training](https://blog.opto22.com/optoblog/topic/training), [CODESYS](https://blog.opto22.com/optoblog/topic/codesys), [IEC 61131-3](https://blog.opto22.com/optoblog/topic/iec-61131-3), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [OptoU](https://blog.opto22.com/optoblog/topic/optou), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio)
### Written by [Norma Rodriguez](https://blog.opto22.com/optoblog/author/norma-rodriguez)
<https://blog.opto22.com/optoblog/author/norma-rodriguez>
Norma is the Director of Training and has enjoyed helping customers solve their problems or learn about Opto 22 products for over 30 years. She enjoys exercising, gardening, and reading.
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
