title: Get ready for groov RIO with Ignition 8
description: A new groov RIO module (MM2) has just been released that includes Ignition 8 software from Inductive Automation.
image: https://blog.opto22.com/hubfs/RIO_IgnitionEDGE_v2_1500.png
# Get ready for groov RIO with Ignition 8
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on May 18, 2021, 8:00:00 AM
### A new *groov* RIO module (MM2) has just been released that includes Ignition 8 software from Inductive Automation.
As announced [previously in the OptoBlog](https://blog.opto22.com/optoblog/epic-news-ignition-8-plus-more-ram-disk-space), Ignition 8 software is now part of the newest *groov* EPIC controller ([GRV-EPIC-PR2](https://www.opto22.com/products/grv-epic-pr2)). But, we didn't stop there. The latest *groov* RIO MM2 model ([GRV-R7-MM2001-10](https://www.opto22.com/products/product-container/grv-r7-mm2001-10)) also includes Ignition 8 and boasts increased memory and storage along with other important features.
#### What does this mean for you?
[![GRV-R7-MM2001-10](https://blog.opto22.com/hs-fs/hubfs/RIO_IgnitionEDGE_v2_1500.png?width=300&name=RIO_IgnitionEDGE_v2_1500.png)](https://www.opto22.com/products/product-container/grv-r7-mm2001-10)In addition to the Power-over-Ethernet (PoE) capability and multi-signal I/O channels of the initial *groov* RIO release ([GRV-R7-MM1001-10](https://www.opto22.com/products/product-container/grv-r7-mm1001-10)), with Ignition Edge 8 onboard, *groov* RIO MM2 can also function as a gateway to PLCs and other third-party devices. Sound like something you could use?
[![GRV-R7-MM2001-10](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/e7b7205c-2812-4b9e-8dcb-1b3c169f35a2.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/e7b7205c-2812-4b9e-8dcb-1b3c169f35a2)
Remember, *groov* RIO is designed to help you in 2 ways:
- **As an edge I/O unit** (I/O for the IIoT), communicating data between field devices and data destinations. You can:
    - Connect directly to sensors, devices, and equipment to acquire data
    - Push data directly to on-premises or cloud apps, databases, or other software, typically using the included Node-RED
    - Publish data to an MQTT broker
    - Respond to Modbus/TCP requests for data
    - Configure its built-in I/O channels through the browser-based interface, as well as configure up to 4 PID loops (firmware 3.0+)
    - Manage user accounts and permissions from a central LDAP server (firmware 3.0+)
- **As traditional remote I/O** for your control strategy:
    - With a *groov* EPIC processor running a PAC Control strategy; add a *groov* RIO as an I/O unit
    - With CODESYS applications, download and install the [Opto 22 CODESYS Library Package](https://www.opto22.com/support/resources-tools/downloads/opto-22-library-package-for-codesys-development-sy) to the CODESYS Development System, then add a *groov* RIO as an Ethernet device
    - With a custom control program through *groov* RIO's OptoMMP memory map, REST API, or through secure shell  (SSH) access (firmware 3.0+ and the free [GROOV-LIC-SHELL](https://www.opto22.com/products/product-container/groov-lic-shell) license)
Use the [online RIO Explorer](https://www.opto22.com/products/groov-rio-explorer)tool to explore the over 200,000 unique field I/O signal options you can create with either model of *groov* RIO.
As always, our team of engineers is here to answer your questions and help you make the right decisions for your application. Give us a call, [contact us](https://www.opto22.com/support/contact-us) through the website, or start a conversation in the live [OptoChat](https://www.opto22.com/).
Keep calm and *groov* on!
 Topics: [IIoT](https://blog.opto22.com/optoblog/topic/iiot), [Ignition Edge](https://blog.opto22.com/optoblog/topic/ignition-edge), [CODESYS](https://blog.opto22.com/optoblog/topic/codesys), [secure shell](https://blog.opto22.com/optoblog/topic/secure-shell), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio)
