title: Get real-time insights to avoid downtime, reduce costs, and optimize your industrial operation
description: New white paper outlines actions you can take for practical and cost-effective machine monitoring with edge devices.
image: https://blog.opto22.com/hubfs/groov%20EPIC%20and%20RIO%20images%20-%20Brand%20and%20Style%20Guide/RIO-Din_Wire-1.png
# Get real-time insights to avoid downtime, reduce costs, and optimize your industrial operation
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Apr 16, 2025, 6:08:48 AM
### New white paper outlines actions you can take for practical and cost-effective machine monitoring with edge devices.
Keeping machines running smoothly is at the heart of every industrial operation. Machine monitoring helps avoid downtime by providing real-time insights needed to catch problems early and keep equipment working.
Have you been tasked with an IIoT (industrial internet of things) or digital transformation initiative for your company? Ready to learn how edge devices can be a part of your solution?
##### Machine Monitoring: Not just for new machines
New technology found in edge devices isn't just for new machines or greenfield systems. Edge devices can also help you get live production data from existing equipment (brownfield systems) to:
- Improve production visibility
- Help predict maintenance issues
- Keep production operating smoothly
[![Edgeconcept\_5x3p5\_150dpi-1](https://blog.opto22.com/hs-fs/hubfs/Edgeconcept_5x3p5_150dpi-1.png?width=524&height=711&name=Edgeconcept_5x3p5_150dpi-1.png)](https://documents.opto22.com/2436_White_Paper_Machine_Monitor_Edge_Devices.pdf)
##### It's time to turn data into action...
Whether you’re integrating legacy systems or enhancing smart machines, edge devices provide the bridge between your equipment and your Industry 4.0 or IIoT initiatives. Now you can turn your existing equipment into a valuable source of real-time data—without costly overhauls or operational disruptions.
Remember, your machines are already working hard—it's time to make them work smarter.
This [white paper](https://documents.opto22.com/2436_White_Paper_Machine_Monitor_Edge_Devices.pdf)helps you get started. Learn how to add an edge device to a single machine or process, capture critical data, and integrate it into your digital infrastructure.
[![DOWNLOAD WHITE PAPER](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/2931e03d-282d-4bad-8eb0-b2803fb44a35.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/2931e03d-282d-4bad-8eb0-b2803fb44a35)
In addition to walking you through the technical steps of adding edge technology, the [white paper](https://documents.opto22.com/2436_White_Paper_Machine_Monitor_Edge_Devices.pdf) includes 5 real-world application stories demonstrating edge device implementation and results.
Learn from the following industries:
- Tier 1 automotive supplier
- Ornamental plant grower
- Oil and gas company
- Water district
- OEM heat treatment
Each solution addresses unique challenges with real results. Are you ready to take the next step?
Start capturing your data and take your operations to the next level. The white paper provides all the steps you need to get started.
 Topics: [machine data](https://blog.opto22.com/optoblog/topic/machine-data), [white paper](https://blog.opto22.com/optoblog/topic/white-paper), [edge computing](https://blog.opto22.com/optoblog/topic/edge-computing), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio), [Edge I/O](https://blog.opto22.com/optoblog/topic/edge-i-o), [machine monitoring](https://blog.opto22.com/optoblog/topic/machine-monitoring)
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
