title: groov EPIC announced as a Finalist in the 2020 Engineers' Choice Awards
description: Vote now in the 2020 Engineers' Choice Awards. We appreciate your vote for groov EPIC!
image: https://blog.opto22.com/hubfs/CTLx_ENG_20EngAward_Finalists_NoRule.jpg
# groov EPIC announced as a Finalist in the 2020 Engineers' Choice Awards
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Oct 21, 2019, 8:00:00 AM
### *Control Engineering* magazine hosts its annual awards program, which highlights some of the best new control, instrumentation, and automation products.
![2020 Engineers' Choice Awards Finalist](https://blog.opto22.com/hs-fs/hubfs/CTLx_ENG_20EngAward_Finalists_NoRule.jpg?width=100&name=CTLx_ENG_20EngAward_Finalists_NoRule.jpg)We're excited that Opto 22's [*groov* EPIC](https://www.opto22.com/products/groov-epic-system) (Edge Programmable Industrial Controller) is once again in the running for an Engineers' Choice award!
Major new features were added to the *groov* EPIC controller this year, making it a repeat contender:
1 - Programming options now include IEC 61131-3 compliant languages like:
- Function Block Diagram (FBD)
- Structured Text (ST)
- Sequential Function Charts (SFC)
- Ladder Diagram (LD)
2 - For greater security in data communications, you can now connect the [GRV-EPIC-PR1](https://www.opto22.com/products/product-container/grv-epic-pr1) to a virtual private network (VPN), and configure the EPIC as a client to connect to an [OpenVPN](https://openvpn.net/) server.
3 - For Ignition users, you can now choose Ignition or [Ignition Edge](https://www.opto22.com/products/groov-epic-system/groov-epic-software/ignition-edge) platforms. Full Ignition gives you access to more Ignition modules, external access to the OPC UA server (no need for a PC!), scripting, and database support.
*But groov EPIC can't get the recognition without your help!*
Please consider submitting your vote for [*groov* EPIC](https://info.opto22.com/this-is-epic-introducing-groov-epic) (edge programmable industrial controller) under its **Industrial Internet of Things Connectivity - Edge Controller** category.
Voting closes December 20, 2019, with winners announced online on February 3, 2020 and featured in the February 2020 issue of *Control Engineering*.
### How to vote
To view the Engineers’ Choice finalists and vote, please click on [this Engineers' Choice voting link](https://gspplatform.cfemedia.com/pe/award-programs) and register, or if you’re already registered, sign into the New Products for Engineers Database.
1. Click the Control Engineering 2020 Engineers’ Choice Awards “Vote Now” box.
2. Select the **Industrial Internet of Things Connectivity - Edge Controller category,** and vote for the***groov* EPIC controller (Opto 22)** .
3. Be sure to click the Review Your Votes and Submit Your Votes boxes at the bottom right of each page to complete the voting process.
### [![groov EPIC system](https://blog.opto22.com/hs-fs/hubfs/groovEPIC-w-Phone.jpg?width=300&name=groovEPIC-w-Phone.jpg)](https://info.opto22.com/this-is-epic-introducing-groov-epic)Why *groov* EPIC?
[See why *groov* EPIC is the best choice for any industrial automation or IIoT application. ](https://www.opto22.com/products/groov-epic-system)**Your votes are appreciated!**
Here's a recap of what you can expect from this Industrial Internet of Things (IIoT) edge controller:
- Dual, independent Gigabit Ethernet network interfaces enable the processor to maintain separate connections to trusted networks (like your controls network) and untrusted networks (like your back office network).
- Security features include built-in configurable device firewall and VPN, user accounts, authentication required for access, no default username or password, data encryption, and security certificate management.
- Processor is protected by an Opto 22 cryptographically signed build, so rogue firmware or software cannot be uploaded to the EPIC.
- Dual USB ports let the processor communicate with touchscreen monitors or connect to your network with approved WiFi adapters.
- HDMI port displays configuration and [*groov* View](https://www.opto22.com/products/groov-epic-system/groov-epic-software/groov-view) HMI on an external large screen, which is also useful for OEM applications where the EPIC system is built into a machine.
- Commission your system with web-based [*groov* Manage](https://www.opto22.com/products/groov-epic-system/groov-epic-software/groov-manage), viewable by authorized users from the integrated touchscreen or from a computer or mobile device.
- Program your EPIC using flowchart-based PAC Control with optional scripting. Or use any IEC 61131-3 compliant language (like Function Block Diagram and Ladder Diagram) with the [CODESYS® Development System](https://www.opto22.com/products/groov-epic-system/groov-epic-software/codesys-(iec-61131-3)) and runtime. Or build your own custom program in C/C++, Java, Python, and more with [Secure Shell access (SSH)](https://www.opto22.com/products/groov-epic-system/groov-epic-software/ssh).
- Easily build the HMI you need for all your systems, devices, and data using *groov* View. Authorized users can securely see your HMI locally on the EPIC's high-resolution touchscreen and from anywhere on any computer or mobile device. You can also build a traditional Microsoft® Windows®-based HMI using [PAC Display](https://www.opto22.com/products/pacdisplaybas).
- Create simple logic flows with [Node-RED](https://www.opto22.com/products/groov-epic-system/groov-epic-software/node-red). Use pre-built nodes to exchange data with equipment, online services, and more.
- Connect to Allen-Bradley® and Siemens® PLCs with the included OPC-UA drivers from [Ignition Edge®](https://www.opto22.com/products/groov-epic-system/groov-epic-software/ignition-edge) (a product of Inductive Automation®) (requires a [*groov* Ignition Edge license](https://www.opto22.com/products/product-container/groov-lic-edge)).
- Efficiently exchange data for IIoT projects using optional [MQTT](https://www.opto22.com/products/groov-epic-system/groov-epic-software/mqtt-sparkplug) communications with Strings or Sparkplug payload, also provided by Ignition Edge Onboard ([requires a *groov* Ignition Edge license](https://www.opto22.com/products/product-container/groov-lic-edge)).
- Choose to run either Ignition Edge or full Ignition on the EPIC processor. No PC needed. Full Ignition adds features like external access to the OPC-UA server, additional Ignition modules, scripting, and database support.
Keep calm and *groov* on!
 Topics: [groov](https://blog.opto22.com/optoblog/topic/groov), [Internet of Things](https://blog.opto22.com/optoblog/topic/internet-of-things), [IoT](https://blog.opto22.com/optoblog/topic/iot), [New products](https://blog.opto22.com/optoblog/topic/new-products), [Awards and recognition](https://blog.opto22.com/optoblog/topic/awards-and-recognition), [IIoT](https://blog.opto22.com/optoblog/topic/iiot), [Industrial Internet of Things](https://blog.opto22.com/optoblog/topic/industrial-internet-of-things), [EPIC](https://blog.opto22.com/optoblog/topic/epic)
