title: Increasing profitability with Ignition, Factory Stack, and groov EPIC
description: Learn the powerful results you can achieve when using Ignition, groov EPIC,  and 4IR Solutions Factory Stack™ cloud platform together.
image: https://blog.opto22.com/hubfs/IACaseStudy_Riveron_GlassManuf.png
# Increasing profitability with Ignition, Factory Stack, and groov EPIC
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Mar 4, 2025, 3:03:01 PM
### Learn the powerful results you can achieve when using Ignition, *groov *EPIC, and 4IR Solutions' Factory Stack™ cloud platform together.
As shown in a [recent webinar](https://blog.opto22.com/optoblog/teaming-up-to-enable-digital-transformation-and-a-unified-namespace-uns) here on the OptoBlog, Inductive Automation often brings together its solutions partners (including Opto 22) to demonstrate complete solution packages.
When using collaborative technologies, you see increased benefits—including an easier path to digital transformation and finally getting the data you need, where you need it.
This Inductive Automation case study is an excellent example of how using a combined solution allowed a glass company to achieve a lean manufacturing goal with a unified reporting system, along with increased efficiency in production.
[![IACaseStudy\_Riveron\_GlassManuf](https://blog.opto22.com/hs-fs/hubfs/IACaseStudy_Riveron_GlassManuf.png?width=600&height=333&name=IACaseStudy_Riveron_GlassManuf.png)](https://inductiveautomation.com/resources/customerproject/glass-company-increases-profitability-with-truenorth-metrics)
[![CASE STUDY VIDEO](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/ec3c4ff5-938e-4a59-85ef-95fce930e280.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/ec3c4ff5-938e-4a59-85ef-95fce930e280)
The [case study](https://inductiveautomation.com/resources/customerproject/glass-company-increases-profitability-with-truenorth-metrics) includes a 10-minute video along with a concise written overview that covers:
- The challenge HMI Glass faced that was causing decreased profitability
- The goals they set to obtain intelligent manufacturing data
- Why system integrator Riveron chose Ignition, *groov* devices, and Factory Stack as the solution
- Details on the project scope and direct results
 Topics: [Case studies](https://blog.opto22.com/optoblog/topic/case-studies), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [Ignition](https://blog.opto22.com/optoblog/topic/ignition), [manufacturing](https://blog.opto22.com/optoblog/topic/manufacturing)
- [groov EPIC (506)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (301)](https://blog.opto22.com/optoblog/topic/groov-rio)
- [snap pac (28)](https://blog.opto22.com/optoblog/topic/snap-pac)
