New case study: Stopping leaks with the help of AI
Posted by Janice Colmer on Feb 11, 2026, 11:04:22 AM
Learn how cutting-edge industrial devices using artificial intelligence (AI) are saving mining companies thousands through early leak detection.
Are you in an industry with strict regulations that require constant remote monitoring? That's what several companies are facing in Peru's mining region.
With miles of mining pipelines in Peru, national regulations require continuous monitoring to prevent spills and ensure safe operation. For mining companies, this means the search is on for practical, cost effective, and sustainable solutions to meet these standards.
Learn how OptoPartner PK Soluciones took on the challenge of stopping pipeline leaks before they stop production.
instrumentation-on-pipe-900
This PK Soluciones application story is the newest addition to the Opto 22 case study library and explains how AI and groov EPIC play an important role in a real-time leak detection system.
For PK, the solution was related to pressure. Changes in pressure along a pipeline can reveal leaks long before they're visible in the field. With pressure as the key indicator, the next challenge was turning that data into clear, actionable information for operators.
See how they built a system that collected readings from multiple pipelines, compared them instantly, and detected abnormalities—all without relying on cloud servers or fragile network links.
Read the complete case study to get a look at the software and hardware solution that gave PK and the mining industry the results they needed—and completely changed the way mining sites are managed.
READ CASE STUDY
Opto-Quote-PK
You can read the case study on our website or download your own PDF copy.
Do you have a groov EPIC or groov RIO success story you'd like to share? We'd love to hear from you! Learn more about the Opto 22 case study program. It's a great way to promote your business, products, and services as well as showcase your company as an industry leader.
Topics: Case studies, Node-RED, CODESYS, groov EPIC, python, AI, mining
Written by Janice Colmer
