title: "OptoNews Tip: More capabilities, more I/O for legacy systems"
description: SNAP-PAC-R1-B programmable automation controller fits on B-series rack, brings older I/O into the SNAP PAC System
image: https://blog.opto22.com/hs-fs/hubfs/OptoNews/snap-pac-r1-b_164x224.png?t=1467736113312&width=164
# OptoNews Tip: More capabilities, more I/O for legacy systems
Posted by [Jean Femia](https://blog.opto22.com/optoblog/author/jean-femia) on Jul 6, 2016, 4:27:33 PM
### Move up to SNAP PAC—and keep racks and field wiring intact
[![SNAP-PAC-R1-B](https://blog.opto22.com/hs-fs/hubfs/OptoNews/snap-pac-r1-b_164x224.png?t=1467736113312&width=164&name=snap-pac-r1-b_164x224.png "SNAP-PAC-R1-B")](http://www.opto22.com/site/pr_details.aspx?cid=4&item=SNAP-PAC-R1-B)Have you seen some of our newer high-density, high-speed, or multifunction [I/O modules](http://www.opto22.com/site/pr_selector.aspx?cid=1&qs=1003) and wished you could use them in your legacy SNAP Ultimate or SNAP Ethernet I/O system?
Have you wanted to build an easy-to-use [*groov* mobile interface](http://groov.com/?__hstc=256016212.9ad34b9358316c229587be2701c27335.1458061256007.1467737390693.1467762210924.343&__hssc=256016212.7.1467762210924&__hsfp=3646994070) for your legacy system?
Or wanted to log a lot more data locally?
If so, be sure to check out the [SNAP-PAC-R1-B programmable automation controller](http://www.opto22.com/site/pr_details.aspx?cid=1&item=SNAP-PAC-R1-B).
Like our other R-series rack-mounted controllers, the R1-B works with our most up-to-date control and HMI software—[PAC Project](http://www.opto22.com/site/pr_details.aspx?cid=1&item=PACPROJECTBAS)—and handles all the latest SNAP I/O modules: [analog](http://www.opto22.com/site/pr_selector.aspx?cid=1&qs=100310031044), [digital](http://www.opto22.com/site/pr_selector.aspx?cid=1&qs=100310071044), and [serial](http://www.opto22.com/site/pr_selector.aspx?cid=1&qs=100310181044).
But it also snaps into a **B-series rack** (the one with the blue connector), just like your SNAP Ultimate and SNAP Ethernet brains. So you can move up to the latest automation hardware and software and **keep the same mounting racks and field wiring** you already have.
- Use the R1-B as a controller or simply as the brain for an I/O unit.
- Get local, removable data storage through a microSD slot that takes microSDHC cards up to 32 GB.
- Set up link redundancy using the controller's two independent Ethernet network interfaces.
- Move up to an integrated FPU (floating-point unit) and substantially larger battery-backed RAM.
- Communicate simultaneously with a variety of systems and equipment using several built-in protocols, including TCP/IP, EtherNet/IP for Allen-Bradley® PLCs, PPP, Modbus®/TCP, SNMP for network management, and SMTP for emailing.
- Access data easily with a RESTful API and HTTP/HTTPS server, available with firmware R9.5a or higher (coming soon!).
- Use our free integration kits to communicate via serial Modbus, DNP3, and Controller Area Network (CAN).
For detailed information about migrating to the SNAP PAC System—options, advantages, and gotchas—see the [SNAP PAC System Migration Technical Note](http://www.opto22.com/site/documents/doc_drilldown.aspx?aid=3149).
[See specs for the SNAP-PAC-R1-B](http://www.opto22.com/site/pr_details.aspx?cid=1&item=SNAP-PAC-R1-B).
[![See the SNAP-PAC-R1-B](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/fadb60c2-4aae-4ebf-a9c3-ea46f7885411.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/fadb60c2-4aae-4ebf-a9c3-ea46f7885411)
 Topics: [Updates](https://blog.opto22.com/optoblog/topic/updates), [optonews](https://blog.opto22.com/optoblog/topic/optonews), [PACs](https://blog.opto22.com/optoblog/topic/pacs), [New products](https://blog.opto22.com/optoblog/topic/new-products), [Migration](https://blog.opto22.com/optoblog/topic/migration), [Integrators](https://blog.opto22.com/optoblog/topic/integrators), [I/O](https://blog.opto22.com/optoblog/topic/io), [OptoNews 2016-07-06](https://blog.opto22.com/optoblog/topic/optonews-2016-07-06)
