title: "OptoNews Tip: Peer-to-peer with REST"
description: Use the new RESTful API in Opto 22 SNAP PAC controllers to make peer-to-peer communication easier. See the sample files.
image: https://blog.opto22.com/hubfs/social-suggested-images/Opto-SNAP-RESTful-PAC-1-315x210-2.png
# OptoNews Tip: Peer-to-peer with REST
Posted by [Jean Femia](https://blog.opto22.com/optoblog/author/jean-femia) on Aug 31, 2016, 4:25:57 PM
![SNAP PAC R-series programmable automation controller with a RESTful API](https://blog.opto22.com/hs-fs/hubfs/social-suggested-images/Opto-SNAP-RESTful-PAC-1-315x210-2.png?width=224&name=Opto-SNAP-RESTful-PAC-1-315x210-2.png "SNAP PAC R-series programmable automation controller with a RESTful API")Here's the latest Code Samples and Tips contribution in our new OptoForum: an example of easier peer-to-peer communication between PAC controllers.
This example takes advantage of the new [RESTful API](https://info.opto22.com/snap-pac-rest-api-thank-you) in SNAP PAC hardware controllers (both the standalone S-series and the rack-mounted R-series).
Download the sample, a single-chart strategy, and you'll be able to read and write to tags on a SNAP-PAC-R1 at our headquarters in California, using the RESTful server on the PAC.
Within the sample you'll see subroutines illustrating how to write (POST) values to a remote PAC and how to read (GET) values from it.
**NOTE:** For this example the PAC-R uses HTTP rather than the secure HTTPS. Make sure when you set up your own PAC that you **don't** put it directly on the Internet. We always recommend that your SNAP PAC controller be located behind a firewall and use the secure HTTPS server.
See the [peer-to-peer sample](http://forums.opto22.com/t/peer-to-peer-via-restful-api/1036).
[![See the sample strategy](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/061b0f07-3605-456e-bd0d-37f8a652ee5e.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/061b0f07-3605-456e-bd0d-37f8a652ee5e)
 Topics: [Internet of Things](https://blog.opto22.com/optoblog/topic/internet-of-things), [Tips](https://blog.opto22.com/optoblog/topic/tips), [IoT](https://blog.opto22.com/optoblog/topic/iot), [optonews](https://blog.opto22.com/optoblog/topic/optonews), [PACs](https://blog.opto22.com/optoblog/topic/pacs), [PAC Control](https://blog.opto22.com/optoblog/topic/pac-control), [API](https://blog.opto22.com/optoblog/topic/api), [REST API](https://blog.opto22.com/optoblog/topic/rest-api), [RESTful server](https://blog.opto22.com/optoblog/topic/restful-server), [OptoNews 2016-08-31](https://blog.opto22.com/optoblog/topic/optonews-2016-08-31), [REST](https://blog.opto22.com/optoblog/topic/rest)
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
