title: Programming with CODESYS and need a Modbus master?
description: Learn how groov EPIC becomes a Modbus master/client with a few easy lessons at OptoU online training.
image: https://blog.opto22.com/hubfs/ModbusMasterCodesys.png
# Programming with CODESYS and need a Modbus master?
Posted by [Norma Rodriguez](https://blog.opto22.com/optoblog/author/norma-rodriguez) on May 16, 2022, 7:30:00 AM
### *groov* EPIC becomes a Modbus master/client with a few easy lessons.
With Modbus continuing to be a popular protocol for industrial devices, the chances are pretty good you will need to write a program to communicate with Modbus slave/server devices more than a few times. The *groov* EPIC controller offers several Modbus communication options, and CODESYS, an IEC 61131-3 compliant development environment, is one of them.
With your PLC programming experience and the [Using *groov* EPIC as a Modbus Master in CODESYS](https://training.opto22.com/path/codesys/using-groov-epic-as-a-modbus-master-in-codesys) course on [OptoU](https://training.opto22.com/), creating a CODESYS project with Modbus master functions will be a breeze.
[![ModbusMasterCodesys](https://blog.opto22.com/hs-fs/hubfs/ModbusMasterCodesys.png?width=287&name=ModbusMasterCodesys.png)](https://training.opto22.com/using-groov-epic-as-a-modbus-master-in-codesys)
The course has step-by-step lessons to help you write your project. The lessons cover:
- The hardware and software you’ll need
- Creating a CODESYS project from scratch
- Making the *groov* EPIC a Modbus Master in the CODESYS project
- Adding a slave to the CODESYS project
- Downloading and running the CODESYS project
As you work your way through the lessons, the end result is a working project and a method to develop subsequent projects. There’s also a quiz at the end to test your knowledge.
Modbus/TCP is fully integrated with the CODESYS Development System application and Runtime on *groov* EPIC.
Check out how easy it is to create your own [Modbus Master CODESYS project](https://training.opto22.com/using-groov-epic-as-a-modbus-master-in-codesys)!
[![CODESYS LESSON](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/0df86d4f-a112-46dc-963e-6cd5366cd1ff.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/0df86d4f-a112-46dc-963e-6cd5366cd1ff)
 Topics: [Training](https://blog.opto22.com/optoblog/topic/training), [Modbus](https://blog.opto22.com/optoblog/topic/modbus), [CODESYS](https://blog.opto22.com/optoblog/topic/codesys), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [OptoU](https://blog.opto22.com/optoblog/topic/optou)
### Written by [Norma Rodriguez](https://blog.opto22.com/optoblog/author/norma-rodriguez)
<https://blog.opto22.com/optoblog/author/norma-rodriguez>
Norma is the Director of Training and has enjoyed helping customers solve their problems or learn about Opto 22 products for over 30 years. She enjoys exercising, gardening, and reading.
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
