title: The move to groov for an IIoT approach in water management
description: New case study explains how Paloma Irrigation and Drainage District bridged the gap between operational technology (OT) and information technology (IT) for seamless data flow and efficient management.
image: https://blog.opto22.com/hubfs/PIDD-Pumps_422.png
# The move to groov for an IIoT approach in water management
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Apr 8, 2024, 12:40:30 PM
### A new case study explains how Paloma Irrigation and Drainage District bridged the gap between operational technology (OT) and information technology (IT) for seamless data flow and efficient management.
The Paloma Irrigation and Drainage District (PIDD) has been operating for over 100 years in Gila Bend, Arizona. It provides essential irrigation and drainage services to 30,000 agriculturally diverse acres and nearly 100 homes. More than just irrigation, the PIDD safeguards the environment and upholds the community's water rights.
The PIDD faced several pressing challenges, including high maintenance costs, limited monitoring and control, and inefficient manual operations. These challenges led them to look at industrial internet of things (IIoT) possibilities, which highlighted the need for a more modern, cost-effective, and data-driven approach to water management.
In this [case study](https://www.opto22.com/products/groov-case-studies/case-study-paloma-irrigation-and-drainage-district), read how PIDD bridged the gap between their operational technology (OT) and information technology (IT) for seamless data flow and efficient management, propelling them into their SCADA expansion.
[![PIDD-Pumps\_422](https://blog.opto22.com/hs-fs/hubfs/PIDD-Pumps_422.png?width=422&height=281&name=PIDD-Pumps_422.png)](https://www.opto22.com/products/groov-case-studies/case-study-paloma-irrigation-and-drainage-district)
You'll learn:
- How and why Raspberry Pi was used as the first step in transitioning to an IIoT solution
- What led PIDD to a more robust and industrial-grade platform
- How MQTT integration proved vital for the district's IIoT roadmap
- Why an advanced solution using Ignition SCADA will be the logical next step
[![READ CASE STUDY](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/e7a80943-478b-4f0e-9bb5-db8b49ce343f.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/e7a80943-478b-4f0e-9bb5-db8b49ce343f)
[![Opto-Quote-Paloma-Irrigation](https://blog.opto22.com/hs-fs/hubfs/Opto-Quote-Paloma-Irrigation.png?width=500&height=500&name=Opto-Quote-Paloma-Irrigation.png)](https://www.opto22.com/products/groov-case-studies/case-study-paloma-irrigation-and-drainage-district)
You can [read the complete case study](https://www.opto22.com/products/groov-case-studies/case-study-paloma-irrigation-and-drainage-district)<https://www.opto22.com/products/groov-case-studies/case-study-apex-energy-replaces-end-of-life-system>on our website or [download a PDF](https://www.opto22.com/support/resources-tools/documents/2414-case-study-paloma-irrigation-and-drainage-dis) copy.
Interested in seeing how other industries and applications meet their challenges? [Visit the *groov* Case Studies Library](https://www.opto22.com/products/groov-case-studies).
 Topics: [Case studies](https://blog.opto22.com/optoblog/topic/case-studies), [Water & wastewater](https://blog.opto22.com/optoblog/topic/water-amp-wastewater), [IIoT](https://blog.opto22.com/optoblog/topic/iiot), [Raspberry Pi](https://blog.opto22.com/optoblog/topic/raspberry-pi), [MQTT](https://blog.opto22.com/optoblog/topic/mqtt), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio), [digital transformation](https://blog.opto22.com/optoblog/topic/digital-transformation)
