Using a serial to USB converter with groov EPIC
Posted by Janice Colmer on Dec 11, 2019, 8:26:04 AM
This newly released video walks you through using a serial to USB converter with your groov EPIC PR1 controller.
In our latest video, Applications Engineer Ben Orchard is back to give you step-by-step instructions for reading serial data via the EPIC's USB port with a RS-232 to USB converter.
To show you how this works, Ben uses the groov EPIC Learning Center (GRV-EPIC-LC) and a GPS device that outputs an
RS-232 data string.
Video: Serial to USB converter with groov EPICWhat kind of converter can you use?
  • An authentic FTDI device
  • RS-232
  • RS-422
  • RS-485
  • Or a powered USB hub to expand your options
What do you want to do with your data?
Hint: it depends on your application...
You'll see how to set up each of these options.
Ready to get started? Watch and learn now!
WATCH VIDEO
Topics: Training, serial, groov EPIC, groov EPIC Learning Center
Written by Janice Colmer
