title: groov RIO, now with OPC UA
description: The latest video in our developer series is a quick start guide for setting up OPC UA on groov RIO.
image: https://blog.opto22.com/hubfs/opcua-thumb.jpg
# groov RIO, now with OPC UA
Posted by [Janice Colmer](https://blog.opto22.com/optoblog/author/janice-colmer) on Sep 14, 2022, 9:43:37 AM
### The latest video in our developer series is a quick-start guide for setting up OPC UA on *groov* RIO.
You heard it here first a few weeks ago in the OptoBlog! [*groov* RIO](https://blog.opto22.com/optoblog/time-to-update-groov-rio-3.4-with-opc-ua-server) is the first universal Ethernet I/O module with an embedded OPC UA server. Now you can connect your favorite OPC UA-compatible SCADA or HMI software directly to your multi-signal, multifunction Ethernet I/O System.
Terry Orchard shows you how simple it is. In his latest [developer video](https://www.opto22.com/support/resources-tools/videos/video-opc-ua-quick-start-tutorial), learn how to set up an OPC UA server on *groov* RIO to accept connections from OPC UA clients and request *groov* data.
<iframe class="wistia_embed" style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;" title="Wistia video player" xml="lang" src="https://fast.wistia.net/embed/iframe/3ncs202i0t" name="wistia_embed" width="400" height="225" frameborder="0" scrolling="no" allowfullscreen data-mce-src="https://fast.wistia.net/embed/iframe/3ncs202i0t" data-mce-style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
##### The new embedded OPC UA server feature is now available on all 3 models of *groov* RIO:
- [GRV-R7-MM1001-10](https://www.opto22.com/products/product-container/grv-r7-mm1001-10)
- [GRV-R7-MM2001-10](https://www.opto22.com/products/product-container/grv-r7-mm2001-10)(with Ignition Edge)
- [GRV-R7-I1VAPM-3](https://www.opto22.com/products/product-container/grv-r7-i1vapm-3) (for Energy Monitoring)
##### You have options to collect and publish data the way you want:
Use any of *groov* RIO's OPC UA Server options to communicate data with OPC UA clients:
- The *groov* RIO's built-in OPC UA server exposes I/O values, PID values, and Scratch Pad areas to clients.
- Downloadable OPC UA Server Node-RED nodes give access to Node-RED messages and flows.
- In the [GRV-R7-MM2001-10](https://www.opto22.com/products/product-container/grv-r7-mm2001-10), use Ignition Edge to access Ignition tags, including to any 3rd party device connections configured via Ignition's built-in drivers.
##### Here are more *groov* RIO resources to help you decide:
- Explore [*groov* RIO Universal I/O field I/O Combinations](https://www.opto22.com/products/groov-rio-explorer) (thousands of them!)
- See the *[groov](https://www.opto22.com/support/resources-tools/documents/2317-groov-rio-data-sheet)*[RIO Universal I/O Data Sheet](https://www.opto22.com/support/resources-tools/documents/2317-groov-rio-data-sheet) or the [*groov* RIO Energy Monitoring I/O Data Sheet](https://www.opto22.com/support/resources-tools/documents/2352-groov-rio-energy-monitoring-unit-data-sheet)
- See how [*groov* RIO fits in your system architecture](https://www.opto22.com/support/resources-tools/demos/groov-epic-groov-rio-architecture)
- Learn more about [power and energy monitoring](https://www.opto22.com/products/power-and-energy-monitoring) with *groov* RIO
- Download the [*groov* RIO product brochure](https://blog.opto22.com/hubfs/groovRIO_Brochure_Web_6-22.pdf)
![RIO\_Brochure\_DiagramJuly2022](https://blog.opto22.com/hs-fs/hubfs/RIO_Brochure_DiagramJuly2022.png?width=800&name=RIO_Brochure_DiagramJuly2022.png)
Keep calm and *groov* on!
 Topics: [Videos](https://blog.opto22.com/optoblog/topic/videos), [Ignition Edge](https://blog.opto22.com/optoblog/topic/ignition-edge), [groov RIO](https://blog.opto22.com/optoblog/topic/groov-rio), [OPC UA](https://blog.opto22.com/optoblog/topic/opc-ua)
- [groov EPIC (511)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (305)](https://blog.opto22.com/optoblog/topic/groov-rio)
- [Ignition (132)](https://blog.opto22.com/optoblog/topic/ignition)
- [PAC Control (53)](https://blog.opto22.com/optoblog/topic/pac-control)
- [Ignition Community Conference (32)](https://blog.opto22.com/optoblog/topic/ignition-community-conference)
