title: "Outside-In Journal: Unboxing the groov EPIC Learning Center"
description: See what's included with a groov EPIC Learning Center and follow step-by-step set up instructions from an Opto 22 engineer.
image: https://blog.opto22.com/hubfs/LC_locking_pin.jpg
# Outside-In Journal: Unboxing the groov EPIC Learning Center
Posted by [Josh Eastburn](https://blog.opto22.com/optoblog/author/josh-eastburn) on Oct 31, 2019, 8:25:22 AM
Curious to get your hands on a [*groov* EPIC learning center](https://www.opto22.com/products/product-container/groov-epic-lc) (LC)? So was I. Lucky me, this was dropped off at my cubicle recently. Let’s see what’s inside!
![groov EPIC Learning Center packaging](https://blog.opto22.com/hs-fs/hubfs/EPIC_LC_case.jpg?width=600&name=EPIC_LC_case.jpg)
#### Build
The case is surprisingly rugged, fit for travel. According to Pelican’s site, if you can’t sink it, drop it, or kick it, it isn’t a Pelican case, and from the feel of it, that’s accurate. It’s solid, and takes an effort to open the latches.
Inside, I see the back of the controller and plexiglass stand packed in high-density foam. Included with the controller are some instructions, which, like any good experimenter, I immediately set aside.
![Learning Center case opened](https://blog.opto22.com/hs-fs/hubfs/LC_locking_pin.jpg?width=512&name=LC_locking_pin.jpg)
I grab what looks like a handle and give it a tug. There’s some resistance, but the controller lifts straight out. After trying to figure out how to safely place it down, I notice the locking pin and finally check the instructions to figure out how to use it.
![Unpacking the EPIC Learning Center](https://blog.opto22.com/hs-fs/hubfs/LC_unpacking.jpg?width=512&name=LC_unpacking.jpg)
After a couple maneuvers, I get the unit upright. In the image below, you can see the two pushbutton/LED indicators, potentiometer and ICTD coupling. Removing one more layer of foam from the case, I find the power adapter and temperature probe and get everything connected.
![EPIC Learning Center I/O panel](https://blog.opto22.com/hs-fs/hubfs/LC_IOpanel.jpg?width=512&name=LC_IOpanel.jpg)
![EPIC Learning Center connections](https://blog.opto22.com/hs-fs/hubfs/LC_controls.jpg?width=512&name=LC_controls.jpg)
![EPIC Learning Center LED switch and DC power socket](https://blog.opto22.com/hs-fs/hubfs/LC_LED_setting_switch.jpg?width=512&name=LC_LED_setting_switch.jpg)
Time to awaken the machine… (It’s not happy)
![EPIC Learning Center module status indicators](https://blog.opto22.com/hs-fs/hubfs/LC_bootup.jpg?width=512&name=LC_bootup.jpg)
After boot-up… (All better!)
![EPIC Learning center ready to go](https://blog.opto22.com/hs-fs/hubfs/LC_ready.jpg?width=500&name=LC_ready.jpg)
#### Configuration
After tapping on “Let’s get started,” I select the “Quick Start” option, which has me create an Administrator name and password. I must have fat-fingered something, though, because the next day, it won't accept the password I thought I used. Since there's no default admin account, my only option is to reset the processor and repeat the configuration. It only takes a few minutes, and I use the opportunity to move the unit to my desk and get my networking arranged.
With that done, I can complete setup from my browser. The processor has grabbed an IP address via DHCP, but I try using the default hostname, instead. It works fine, and I follow the included instructions to activate and install the license. While I’m at it, I grab the latest firmware and install that also. I find all of this at [manage.groov.com](http://manage.groov.com) using the included activation key.
![groov Manage](https://blog.opto22.com/hs-fs/hubfs/LC_groovManage.png?width=473&name=LC_groovManage.png)
![groov Manage](https://blog.opto22.com/hs-fs/hubfs/LC_groov%20Manage2.png?width=473&name=LC_groov%20Manage2.png)
As a last step, I set up a demo user account without admin privileges. The default permissions are pretty restricted, and it seems like this user can only launch [*groov* View](https://www.opto22.com/products/groov-epic-system/groov-epic-software/groov-view).
![User accounts](https://blog.opto22.com/hs-fs/hubfs/LC_useraccount.jpg?width=500&name=LC_useraccount.jpg)
Now that the unit is all set up, I explore the I/O modules a bit. The DC output card has a big bundle of wires, so I move its front cover to the extended position. You can see it sitting slightly in front of the others in the image below of the LC nestled into its permanent home on my desk.
![20191030\_172438](https://blog.opto22.com/hs-fs/hubfs/20191030_172438.jpg?width=473&name=20191030_172438.jpg)
Next, I need to load [PAC Project](https://www.opto22.com/products/groov-epic-system/groov-epic-software/pac-control) and [CODESYS](https://www.opto22.com/products/groov-epic-system/groov-epic-software/codesys-(iec-61131-3)) on my PC so I can put this bad boy through its paces. I also really want to try [MQTT](https://www.opto22.com/products/groov-epic-system/groov-epic-software/mqtt-sparkplug) communication with [Node-RED](https://www.opto22.com/products/groov-epic-system/groov-epic-software/node-red). More on that in another post.
#### Conclusion
I’m glad to have my LC ready to go. It was quick to set up and will be useful for testing and training as I familiarize myself with everything *groov* EPIC can do. I really liked the build quality also, and it looks good on my desk. Opto 22 loves hardware, and I think that’s evident in this product. Take a look at the [Opto 22 product selector](https://www.opto22.com/products/product-selector) to find more than 700 finished goods made on site. Here are the folks that built mine:
![Opto 22 manufacturing](https://blog.opto22.com/hs-fs/hubfs/LC_factory.jpg?width=512&name=LC_factory.jpg)
And just for fun, here are some of the other faces of Opto 22 and their awesome test rigs.
![Opto 22 engineers](https://blog.opto22.com/hs-fs/hubfs/LC_OptoEngineers.jpg?width=600&name=LC_OptoEngineers.jpg)
#### Opto 22. By engineers. For engineers.
See you next time!
 Topics: [Training](https://blog.opto22.com/optoblog/topic/training), [IIoT](https://blog.opto22.com/optoblog/topic/iiot), [groov EPIC](https://blog.opto22.com/optoblog/topic/groov-epic), [groov EPIC Learning Center](https://blog.opto22.com/optoblog/topic/groov-epic-learning-center)
### Written by [Josh Eastburn](https://blog.opto22.com/optoblog/author/josh-eastburn)
<https://blog.opto22.com/optoblog/author/josh-eastburn>
After 12 years as an automation engineer working in the semiconductor, petrochemical, food and beverage, and life sciences industries, Josh Eastburn works with the engineers at Opto 22 to understand the needs of tomorrow's customers.
[LinkedIn](http://linkedin.com/in/jkeastburn)
- [groov EPIC (507)](https://blog.opto22.com/optoblog/topic/groov-epic)
- [groov RIO (302)](https://blog.opto22.com/optoblog/topic/groov-rio)
