title: "OptoNews: Visualizing water usage in a drought"
description: California's drought - how data can help
image: https://blog.opto22.com/hubfs/OptoNews/drought_464x308.png
# OptoNews: Visualizing water usage in a drought
Posted by [Jean Femia](https://blog.opto22.com/optoblog/author/jean-femia) on Apr 15, 2015, 5:17:00 PM
[![Drought](https://blog.opto22.com/hs-fs/hubfs/OptoNews/drought_464x308.png?width=224&name=drought_464x308.png "Drought")](https://blog.opto22.com/optoblog/visualizing-water-usage-with-groov)You've probably heard about the continuing drought in California.
The [U.S. Drought Monitor](http://droughtmonitor.unl.edu/Home/StateDroughtMonitor.aspx?CA) at the University of Nebraska-Lincoln currently categorizes **more than 94%** of the state's total area as in "severe drought" or worse, and notes that snowpack statewide (from which we get most of our water through the year) is at only 5% of normal.
The worst-hit area is the center of the state, especially the Central Valley that produces many of the vegetables, fruits, and nuts that appear on dining tables throughout the U.S.—and the world.
With so little precipitation Californians have to conserve the water we have. And the best way to do that is to **start with data**.
Opto 22's Ben Orchard wanted his whole family to see [how they're using water](https://blog.opto22.com/optoblog/visualizing-water-usage-with-groov)—because once you have data, patterns become visible and you can make intelligent changes.
Data is powerful.
[![Water use graphs in groov](https://blog.opto22.com/hs-fs/hubfs/OptoNews/groov_water_use_graphs.png?width=464&name=groov_water_use_graphs.png "Water use graphs in groov")](https://blog.opto22.com/optoblog/visualizing-water-usage-with-groov)
**Take a look** at [Ben's latest blog post](https://blog.opto22.com/optoblog/visualizing-water-usage-with-groov) and see how he installed a water meter and set up a *groov* mobile interface that works on all his family's devices. No excuses about not being able to see the data: it's visible on pretty much any smartphone, tablet, laptop, etc.
[![Read the blog post](https://hubspot-no-cache-na2-prod.s3.amazonaws.com/cta/default/439485/530916f8-2a26-41ed-af9b-a218a699a633.png)](https://hubspot-cta-redirect-na2-prod.s3.amazonaws.com/cta/redirect/439485/530916f8-2a26-41ed-af9b-a218a699a633)
### OptoNews April 15, 2015 - Read more in this issue:
- [New HVAC demo in PAC Project Demo](https://blog.opto22.com/optoblog/optonews-hvac-pac-project-demo)
- [Free lunch and plenty of tech](https://blog.opto22.com/optoblog/optonews-allied-mobile-tech-day)
- [Tech tip: Just 2 wires to your dry contact switch](https://blog.opto22.com/optoblog/optonews-tech-tip-2-wires-to-switch)
 Topics: [groov](https://blog.opto22.com/optoblog/topic/groov), [Remote monitoring](https://blog.opto22.com/optoblog/topic/remote-monitoring), [Water & wastewater](https://blog.opto22.com/optoblog/topic/water-amp-wastewater), [optonews](https://blog.opto22.com/optoblog/topic/optonews), [OptoNews 2015-04-15](https://blog.opto22.com/optoblog/topic/optonews-2015-04-15)
